I'm just about to take off the input flange nut to replace the seal, when i noticed that the input flange to the diff is very not centered in the subframe hole. The diff is mounted to the the subframe, off the car, no trailing arms or axles attached. is this normal???
Should diff input flange be centered in subframe hole?
It could be off but it should be very close to centered. That would be on the car...Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
"I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama -
Do you think the area the diff bolts to on the subframe is flexy enough to allow for this much flex? And if so i guess once mounted, the car will hold it straight? i dunno.. it seems pretty solid to me. I wonder if my subframe is tweaked somehow. Its a solid inch off center.Comment
Put a square to it and measure it. Make sure you measure it like a box for squareness. That's the best way to do that but it's hard to tell with it off the car. It would seem obvious if it was bent.
Pics??Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
"If you've got a business, you didn't build that. Somebody else made that happen" Barack ObamaComment
mine was like that too. Don't worry, it's fineRecent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
