Flex Disc-Guibo Coupling
  • JoeMadoo
    • 936
    What are the two sizes for the Flex Disc-Guibo Coupling between E30's. I know one is larger and one is smaller, which one is the 96mm?
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
  • e30_325es
    • 1249
    Large
    • JoeMadoo
      • 936
      So according to pelicanparts, after 5/86, they were all large on E30's. So the larger of the two would work with the m30 swap correct?
      '86 E30
      '05 E53 X5
      '72 Firebird
      '10 Prius
      '03 Tundra
      • Mike325
        • Mar 2006
        • 3685
        If you are useing the same trans as the m20 and the front half of your driveshaft then it should be ok.
        Originally posted by Kershaw
        • browntown
          • Jun 2004
          • 3524
          There is a part interchange with the beefier m5 guibo, do a search, might as well.
          http://e30m3performance.com/installs...uibo/index.htm
          • JoeMadoo
            • 936
            Well the internet lied. My transmission/driveshaft from a 90 325i had a little one.
            '86 E30
            '05 E53 X5
            '72 Firebird
            '10 Prius
            '03 Tundra
            • Rocla
              • 922
              AFAIK, only certain etas and 324td's have large guibo.
              Current:
              BMW 320i 2d 2.0 m20 -88
              BMW 325i Cabriolet 2.5 m50 -88
              BMW 316i touring 1.6 m40 -90
              BMW 320i 4d 2,2 m54 -01
              • netcsk
                • Apr 2004
                • 1609
                yeah, an eta from 5/86 has the large guibo. All other (american) e30s have the smaller.
