alright, when i took out my subframe to do bushings i noticed 3 sets of marks on my driveshaft, one set that i made to line it up right another set that is lined up when mine are lined up and a third set that is about 1/2in away from being lined up when the other 2 are lined up. the problem here is that i dont know which set is correct.
i get a vibration through the car above 60mph but i am running urethane rsms and tabs, do you thing i should try the other set of marks since ill be doing a clutch job soon anyway?
