proper tools?
  • viali8
    • Nov 2005
    • 673
    proper tools?
    I am thinking about doing the auto to man. swap. can anyone tell me what tools i would need to get the job done. thanks Matt
  • rs4pro3
    • 5808
    torx sockets, some long extensions, then just the normal tools, maybe a thin wall 30mm if you plan to change the seals
    85 325e 2.7 ITB'd stroker
    • viali8
      • Nov 2005
      • 673
      thanks
      • MikeE30325i
        • 2356
        there is a post in "transmission and driveline" that details the swap. though the pics dont work anymore. hope that helps.
        • viali8
          • Nov 2005
          • 673
          yeah, i wish the pics were still there. thanks
          • ptownTSI
            • Jun 2005
            • 1265
            you need a complete E torx set from E8 to E16, flare nut wrench set about 9mm i think for the slave cylinder, a slave cylinder and clutch master cylinder since they all use soft brass connections and you must use a flare nut wrench.
            • matt
              • 3732
              The hydraulic connectors are 11mm
