Easy way to get 30MM nut on 260 off?
  • DEV0 E30
    • Oct 2004
    • 8903
    For the output shaft seal on a Getrag 260. I've tried a few different ways and ended up not putting a new seal on my tranny in my current dd. There is a 30MM nut that is pretty hard to get off since you can't really get any leverage on it. (I snapped off a tranny tab for the tranny mount before trying to pry it off. ) So I want a 3 leg puller, or a secret way to get a new seal on there, any ideas? Or know of any 3 leg puller websites, I'd like to have one for rear bearings, and other stuff.
    Part 13=
    http://realoem.com/bmw/showparts.do?...80&hg=23&fg=15
  • NC325iC
    • Mar 2004
    • 6565
    in the car or out
    i just did this recently out of the car
    i cut notches in a bit of wood so it would bolt up to the flange to keep it from spinning and used a breaker bar and a cheater
