Getrag 260's
    Getrag 260's
    Are all 260's the same -
    Will one from an E34 M20 fit right into an E30 with no mods, esp to the drive shaft?
    This is the model getrag I speak of "260-0-1346.91" is this the same p/n as an E30 item?
    TIA
    It should work, but I'm not 100% certain. You may have to swap output flanges. Double check that the flanges for the trans mounts are the same as well.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
      The 325iS Evo's didn't come with the same box as the std 325i.
      It had a sport box... dunno the part no. but it's the same box that came on the British 325i Sport.
      with 1st-3rd close ratio.
