Well actually i guess its the clutch pedal or i dont know. This morning i start my car and go to put it into first and i notice that the clutch pedal has very little pressure. Almost liek when you bleed brakes and you can push all the way to the floor with very little happening. So i had to press the pedal to the floor super hard in order to change gears. I was at my friends house over night about 10 miles from my house and while i was driving it stayed like this. Is it as simple as jsut ajusting the pedal? or could i have some major problems comming up. Clutch doesnt slip and is fine.
Clutch Problems
Tags: None
Didn't you ask this in another section last night?Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
