I replaced the input shaft seal, output shaft seal, selector seal (that was leaking badly). I'm ordering a backup light sensor tomorrow, and the clutch kit is sitting in the box, patiently waiting to go in.
There's another cap/cover under the input shaft inside the bell-housing. secured by a this ring-thingamacallit. Is there anything I need to replace there?
I'm also redoing all the shifter parts... I also have a bunch of seals for the engine, which brings me to my next concern: There was a lot of gunk and oil all over the bell housing, however, the input shaft seal wasn't leaking.. When I take the flywheel off, should I expect a mess on the engine side? Like I said, I already have a bunch of seals for that stuff, as well as the pilot bearing..
Oh, of course, I must boast about being able to remove the starter with the bitch nuts from underneath the car without removing a single part from the top to get to it.. :pimp:
