U-joint - how to figure out if its good/bad ?
  • bala_eos
    • Sep 2004
    • 58
    I have the driveshaft off the car (87 325i/5-speed). Both the front and rear u-joints feel just a tiny bit notchy.
    They move fairly freely but it feels like there is a soft detents. I couldn't sense any play in the joints either.
    Are the U-joints shot or is there any other way to tell if its good/bad ?
    thanks,
    Bala
  • More&Faster
    • Jan 2007
    • 61
    if you can feel play in them, i believe they're bad.
    • bala_eos
      • Sep 2004
      • 58
      I didn't feel any play.
      Just a slight bit of notchiness.
      • netcsk
        • Apr 2004
        • 1609
        notchiness is not a good sign. It will eventually get worse and before you know it, the joint will seize. You may want to source a good used one or a new/rebuilt one. At the same time, you'll be fine for quite some time longer unless you're really hard on your drivetrain. I'm convinced a bad rear joint is what tore the fairly new differential bushing on my car.
        • AdamF 88iS
          • 2051
          They either get wobbly loose or seize up, depending on the conditions that caused them to go bad.
          They should move smoothly with slight resistance due to tight fit.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • PiercedE30
            • Apr 2005
            • 4220
            ANY form of notchiness is a sign of a bad u-joint
            My 2.9L Build!
            • bala_eos
              • Sep 2004
              • 58
              Greaseable U-Joints (rebuilt driveshafts)
              For those with rebuilt driveshaft with Greasable U-Joints, how often do you grease the joints ?
              How easy difficult is it ?
              • Garageaholic
                Freestyle Fabricator
                • Dec 2005
                • 5204
                Notchiness is bad. Get a new driveshaft asap
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                Instagram.com/garageaholic
                Youtube.com/garageaholic
