As the title states, I rebuilt my tranny with 69 miles on it (due to being in the gulf region) and just recently had the torque converter and valve body re-worked. After putting everything back together the car doesn't want to move. You can hear the gears shift when selecting D,R, 123, etc. but no movement. Any thoughts on this??
Auto Tranny(car does not move)
Put fluid in it . :D
Did you do the "rebuild" yourself ?
If so then you should be able to traqck down the problem .
Is the engine just revving up while the trans is in gear ?
Did you put in a new clutch-pack ?
And WTF do you mean by "reworked" torque converter ? -
The torque converter was modified by IPT as well as with the valve body.. Can't do a five speed swap here since its hard to find parts and shipping overseas is expensive. The tranny was fully rebuilt with all new clutch packs rings, seals etc.. I checked the fluid level and its seems to have enough fluid in it. it takes about wat 4 qts??"Driving anything else would be uncivilised"Comment
