1988 528 SuperETA manual tranny on 1990 325i Auto
  • i6turbo
    • Apr 2007
    • 15
    Will the tranny from the 528 bolt up to the 325i without issue? becasue mines is auto and i want 5spd. Also, if so what are the gears like on it? thanks
  • matt
    • 3732
    The gears are round and have little teeth on them that fit into other gears.
    Nothing ever bolts up without issue, but yes you can make that work.
    • i6turbo
      • Apr 2007
      • 15
      I didnt mean without issues like drop in and go. I just need to make sure the trans fits. But i donno if its gonna be good with the 4.1 rear from the auto..
      LSD both tires spin or one spins? thanks
      • i6turbo
        • Apr 2007
        • 15
        also by gears i meant, wat are the ratios? if they are the same as the 325I manual model tranny. Thanks
        • matt
          • 3732
          The ratios are the same.
          LSD = both tires spin
          • i6turbo
            • Apr 2007
            • 15
            Thanks alot
