Transmission Replacement - What do I need?
  • DarkWing6
    • Apr 2004
    • 7144
    Since I will be replacing my tranny what do I need to purchase (seals wise, etc)? Also, what should I replace while I am in there?
  • Mr.SWISS
    • Nov 2005
    • 1251
    Clutch., pilot bearing.
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
    • PiercedE30
      • Apr 2005
      • 4220
      Input shaft seal, output shaft seal, shifter seal, tranny mounts (unless done recently), would suggest rear crank seal (unless done recently). I believe that should be about it.....just did two cars at work......
      My 2.9L Build!
        • 37833
        Throwout bearing too.
        You should at least get your flywheel resurfaced too, and getting it lightened would be awesome.
        Grover Beach, California
        BimmerHeads.com
        • backtrail69
          • Jul 2005
          • 4471
          Shifter/bushings if you haven't already. Guibo, CSB, driveshaft centering bushing, tranny mounts and keep in mind if you pull the rear main you have to do the oil pan...
          :: PNW Crew ::
          '87 325 4dr, '74 2002
