Driveshaft collar nut
  • bala_eos
    • Sep 2004
    • 58
    I got a re-manufactured driveshaft (portland - driveline services).
    I am not able to loosen the collar nut on it - i tried it with a adjustable wrench/plier. I tried with the driveshaft in the car and out the car.
    I sprayed a bunch of PBBlaster too.
    When I removed the old driveshaft, the collar nut was only hand tight.
    Is it necessary for the collar nut to be only hand tight ? Or can I just leave it as is ? I can fit and remove the driveshaft as is.
    If I have to loosen it, what are my options ? I tried the local sears/autozone/etc. to find a big enough wrench without any success.
    thanks,
    Bala
    PS: Damn the two piece driveshaft :-(
  • PeaveyBassist
    • Sep 2004
    • 3511
    It will be fine as is. Although it might be a little harder to compress it when taking it off next time though. It will be fine though.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • bala_eos
      • Sep 2004
      • 58
      So, once in the car, they don't slide on the splines ?
      • Mr Deagle
        • 1121
        it slides maybe a couple thousandths of an inch when you are driving, or if your chassis is flexing
        • ldsbeaker
          • Aug 2004
          • 3098
          Sorry to bump such an ancient thread.
          The collar nut on the driveshaft:
          It's regular lefty loosey, righty tighty, correct?
          I'm having trouble, and don't want to crank on it the wrong way...
          Thanks!
          Slicktop City!
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            Thanks!
            Yes, regular lefty loosey
            -Andy
            • Mohammed_A
              • 344
              How tight should it be?
              • dashboardmonkey
                FUCK YOUR WAFFLES
                • Jun 2008
                • 6158
                Pretty snug, but not wrenched on real hard.
                -Andy
                • gearheadE30
                  • Jun 2007
                  • 3734
                  just discovered mine was completely unscrewed... I accidentally pulled the driveshaft in half with the diff out.
                  Project M42 Turbo
