Euro 6 speed
  • Eric
    • 5142
    Euro 6 speed
    so I was thinking while bored at work today.
    does this logic work?
    M50 fits M20 transmission.
    M20 then fits M50 transmission
    M50 fits S50 transmission
    S50 fits a Euro S50 transmission
    If M20 can fit an M50 transmission, and an M50 can fit a S50 transmission, then a M20 can fit a S50 transmission, and a euro S50 transmission?
    what do you think?
  • silversleeper
    • Mar 2005
    • 2032
    There are plenty of times I feel the need for a 6th gear on the highways... this would be great if it worked. Sadly enough though, my budget would never allow it to be so.
    Claus Luthe is my hero.
    • erik325i
      • Jan 2005
      • 3567
      Yes, it should work, but here are some things to think about.
      1) The euro 6-speed costs more than the average e30
      2) You would have to build a custom tranny bracket to rotate the tranny 10* because of the differences between the m20 and s50
      3) You would need a shorter driveshaft. (probably custom because I doubt you'll find one the right length)
      -Erik
      • FredK
        • 14760
        Nah, you can use an automatic E36 M3 driveshaft, but you'd have to change the center bearing support with an E30 unit.
          If memory serves, 6th gear in a Euro tranny is the pretty much same ration as 5th in a Getrag 260 (0.82 vs 0.81). So all you gain in more lower road speed ratios. I think the driveshaft length is different, so a modified DS would likely be required.
          • bumpstop335i
            • Mar 2006
            • 64
            If you match the diff ratio to the gb, should turn out pretty mean.
            I went the other way and went 4spd. Now, I do 60mph @ 3500rpm. not good with a 3.46 diff. I have just purchased the (new to me) 2.79 crown and pinion gears to make more use of the torque i have.
            • xLibelle
              • Aug 2004
              • 2673
              this is crazy enough for me to try. i'll have my people get on with finding me a tranny a sap
              • golde30
                • 11464
                what do you think?
                transitive property applied to e30's eh? nice.
                IG: @Baye30
                • Eric
                  • 5142
                  better than the chip+intake+exhaust=50 horsepower calculator right?
                  so for more thinking.
                  6 speed is longer than the 5 speed.
                  325ix requires a shorter driveshaft due to the transfer case...hmmm.
                  rotating the tranny mounts 10 degrees:
                  how do normal S50 conversion guys do it?
                  lower the diff ratio that the normal 6 speed cars have should provide nice cruise speed. not concerned about top speed, 240kph in an E30 is scary enough!
                  • xLibelle
                    • Aug 2004
                    • 2673
                    [OT]lol, damn you eric, you live 30 minutes from the ring... come join us next weekend... and bring an extra car for me[/OT]
                    • Eric
                      • 5142
                      your going to be here when?
                      I can this weekend but not the next.
                      I'll be in DCU's on the 19th : (
                      • xLibelle
                        • Aug 2004
                        • 2673
                        oh [/end offtopic]
                        • 92 mtechnic cabrio
                          • 4907
                          what do you think?
                          I've thought the same logic over and over.
                          R.I.P 07/01/09 - 04/23/10 :(
                          • Bmjpv
                            • Mar 2007
                            • 561
                            To you techs that know the e30 combo that work with 24v swaps. My 24v,95zf,and 3:25 runs too high of rpms at cruise. Aprox 4k at 70mph, I love the pull the car has threw the gears but I need better cruising rpm. The next rear gearing is ,what 2:93? So 2:93 and a 6 speed?? What works?? thanks joe
