engine rpm at speed?
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Just a reference question: My 325iS hits 3000rpm at ~71mph (I'm guessing the speedo is pretty close). This seems like a really fast engine speed for a fairly low road speed. What kind of speeds do you guys get? I checked my tranny and diff, the tranny is marked Getrag 260 and the diff is marked S 3.73 so they appear to be stock. However the car was originally an auto, and I was under the impression that 325iS AT's came with 4.10 gears. But the tag definitely says 3.73. I suppose there is a chance the tag was changed and not the diff for some dumb reason, but I doubt it.
  • backtrail69
    • Jul 2005
    • 4471
    That sounds about right. I am trying to remember what my 325is is at about 70 but I haven't driven it on the freeway in months.. I will this sat tho.. :D
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • browntown
      • Jun 2004
      • 3524
      Differential 3.73
      Aspect Ratio
      Width Diameter
      Enter tire size: 215 40 17
      Ratio 3.71 3.83 2.20 1.40 1.00 0.81
      RPM 1st 2nd 3rd 4th 5th
      750 4 4 6 10 14 18
      1000 5 5 9 14 19 23
      1250 6 6 11 17 24 29
      1500 8 7 13 20 28 35
      1750 9 9 15 24 33 41
      2000 10 10 17 27 38 47
      2250 11 11 19 30 43 53
      2500 13 12 22 34 47 58
      2750 14 14 24 37 52 64
      3000 15 15 26 41 57 70
      3250 17 16 28 44 62 76
      3500 18 17 30 47 66 82
      3750 19 19 32 51 71 88
      4000 20 20 34 54 76 94
      4250 22 21 37 58 81 99
      4500 23 22 39 61 85 105
      4750 24 24 41 64 90 111
      5000 26 25 43 68 95 117
      5250 27 26 45 71 99 123
      5500 28 27 47 74 104 129
      5750 29 28 50 78 109 135
      6000 31 30 52 81 114 140
      6250 32 31 54 85 118 146
      6500 33 32 56 88 123 152
      6750 34 33 58 91 128 158
      7000 36 35 60 95 133 164
      • Ravennexus
        • Sep 2006
        • 16
        weird that you guys got 3.73 diffs.
        my 87 325i with auto and 3.64 (used in both manual and auto cars here) runs 2600 at 70. i'm tempted to get a 3.91 for it
        • CorvallisBMW
          • 13039
          huh, I guess it's pretty normal then. If i get around to my stroker this summer I will def. change to a higher geared rear end, seeing as how I tend to be on the freeway alot.
