Originally posted by Mike325
View Post
Vibration while in 2nd gear ?
Wait a sec, I really don't know how this works in E30's, but in Muscle cars, if you mount the driveshaft (let's say) 25º off, or 180º off the way it was before, it will rattle your teeth because of balance issues, have them check the balance of the driveshaft, when unbalanced they usually vibrate at a very close rotation speed range.
This may have unbalanced the driveshaft/tranny (when looked at as a unit) what I'm triying to say is that maybe the driveshaft was compensating an imbalance or misalignment of the tranny, so when mounting the driveshaft off in xº the imbalance could be noticeable.
Have you checked if the car vibrates also at the same revs in third gear ?
PLease disregard if all this does not apply to E30's
Just my.
Originally posted by ivo316 View PostWait a sec, I really don't know how this works in E30's, but in Muscle cars, if you mount the driveshaft (let's say) 25º off, or 180º off the way it was before, it will rattle your teeth because of balance issues, have them check the balance of the driveshaft, when unbalanced they usually vibrate at a very close rotation speed range.
Just my.
Originally posted by blunt View Postis the shop that did the work BMW knowledgeable? i bet they separated the d/s and its out of phaseMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by JGood View PostI assume you removed the driveshaft. when you reinstalled it, did you preload the CSB to the front 4-6mm? I killed 4 or 5 of them on various e30's by not doing that, but since I started doing that I've had no problems.
Ryan is right, the problem is most likely the u-joint(s). Driveline Service of Portland sells remanufactured driveshafts for BMWs with serviceable u-joints, but some people have had bad experiences with them, since the u-joints they use are Nissan pickup units. Most people I've talked to have had no issue with them, but there are always exceptions. The next easiest route is to try and find a low-mileage used shaft and have it rebalanced yourself.
If it's the driveshaft I am putting this car on hold, I don't want to deal with tranny/driveshaft twice. :(Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
