So I've had a small clunk in the rear for some time now. It will occur when parallel parking, mostly. As I am backing up into the space, as soon as I hot the brakes, CLUNK. When doing the rear brakes yesterday, I grabbed the halfshaft close to the diff and tried turning the brake rotor (e-brake set). I can feel the play causing the clunk in the u-joint closest to the hub. The other side has VERY little play. Is this cause for concern? Is there anything to do except replace the halfshaft (@$350)? Thanks for your opinions -
Jack
Jack
