bolt on diff. swap or not??
  • wastedincome
    • Aug 2004
    • 906
    I have a 92' 318iC (vert) w/ a toasted 4:27lsd. I have access to a 4:10 lsd from a M3. I'm not really sure on the small case vS. large case compatiblity factor. Will this be a bolt on or not?? If noty what do I need to swap to make this work?
    Wastedincome420@yahoo.com
    CURRENT STOCK LIST:
    00' e38 750iL HighLine=Highway Queen
    92' e30 318 vert=Aint going anywhere
    91' e34 535iM=Aint going anywhere
    91' e34 525iA=For parts
    92' e34 535iA=For parts
  • wastedincome
    • Aug 2004
    • 906
    Anybody?????
    CURRENT STOCK LIST:
    • dj2xrated
      • May 2007
      • 540
      aw man .. idont about this i was looking for the answer to a similar question . is the lsd a bolt on to any e30 or no? is any e30 diff interchangeable. whoever has the answer to ur ?/ should or might be able to answer mines too
      Operation S/C E39M5.:woowoo:
      • Mr Deagle
        • 1121
        Any e30 diff will fit in another e30
        Small case needs small case input shaft, and output shafts
        Medium case needs medium case input shaft, and output shafts
        • e30_325es
          • 1249
          All of which "should" come with the differential.
          • Mike325
            • Mar 2006
            • 3685
            Small case is not as strong as the medium case FYI.
            Originally posted by Kershaw
            • dj2xrated
              • May 2007
              • 540
              uuuuuuhhh cases?...que amigo no entiendo , mas problemas with my e30knowledge.
              i think spanish class is helping. hehe
              • FredK
                • 14763
                The input shafts are the same.
                • pedal2metal
                  • Jun 2007
                  • 93
                  i thought the 318 had a shorter distance between the 2 mounting holes on the very top of the diff. which would mean you would have to swap the rear subframe to accomodate the m3 case. the 4:10 i got out of an m3 bolted right up to my 89 325i with no issues.
                  could be wrong though, hope it helps
                  • Teaguer
                    • Sep 2004
                    • 6167
                    OK listen up :
                    The bigger (med) 6cyl E30 diff is a direct bolt-in replacement for the 4cyl small case differential .
                    No need to swap output flanges, covers or anything .
                    No modifications necessary other than getting the right ratio for your needs .
                    I've swapped in a M3's 4.10 and an 325is' 3.73 into my 318is without changing anything .
                    Here is the M3's 4.10 w/Mcoupe cover in the 318 :
                    I've got side by side pics of the small case versus the medium case on my work pc that I can post if need be .
                    Pedal2metal : You know thats an E21 in your avatar , right ?
                    • pedal2metal
                      • Jun 2007
                      • 93
                      its still a rad pic.
                      post the pics of the small/large cases...whats the difference?
                      • Jean
                        • 18228
                        Like Teaguer they fit just fine w/o any modification. I've installed a 325i s3.73 on my 318i 4cyl w/o doing any modifications at all and it fit just fine.
                        • pedal2metal
                          • Jun 2007
                          • 93
                          are the eary etas different?
