what gearbox for m40 manual?
  • payney8
    • Jun 2007
    • 899
    hey guys i just bought a 1989 e30 318i and im converting it to manual. What gearbox would i need for the m40 engine? i have searched and all ive found is u need a getrag 260 for an m42 and no answer for the m40? also i bought a parts car that has an m10 am i able to use all the manual parts ie slave/master and pedal box for the m40?
    any help?
    thanks
  • payney8
    • Jun 2007
    • 899
    any help guys
    • payney8
      • Jun 2007
      • 899
      come on guys
      • James Crivellone
        Head Janitor
        • 6305
        Please keep in mind many few here have physically seen an M40 car, let alone worked on one. I have seen several, but have not worked on any of them.
        The M40 and M42 share the same Getrag transmission, so any one from a M42 equipped car should work out alright.
        In terms of the M10 parts car, I do not beileve the Getrag 240 will bolt up to the M40
        • ron1999
          • May 2007
          • 122
          M40 uses the same engine block as the M42.
          My 316I has a getrag 240, and several M42 cars came with getrag 240 as well - so there should be no problem coupling an M40 with GR260 or an M42 with GR240.
          another important thing is that the M40B16 and the M40B18 uses the same gearboxes - FYI.
          what im not sure about is the differences between those two.
          Ron.
          • payney8
            • Jun 2007
            • 899
            well ive found out today that the gearbox from the strip car with the m10 motor does not fit up. The gearbox bolt holes are slightly different. I believe its a getrag 240. But also i found out that the scrap car has a brand new clutch and a lightned flywheel. Can i swap these parts over to the 260? it seems to be possible. Any help?
            • payney8
              • Jun 2007
              • 899
              any help?
              • payney8
                • Jun 2007
                • 899
                lsitens to the birds singing while waiting 4 an answer
