Clutch Assembly diagram
  • fwappy
    • Feb 2007
    • 362
    I'll be doing the long awaited auto to manual swap this week after work on days that I'm not too worn out. I've never actually installed a tranny or clutch, but I have ALL the parts and it seems pretty simple for a mechanically inclined person like myself.
    Are there any diagrams showing the proper assembly of the clutch parts into the bellhousing, and any other miscellaneous stuff I need to know?
    Also, any tips/pointers on anything, like replacing the seals, bleeding, etc?
    Thanks.
    "If I were filthy rich I'd still drive my E30."
  • DEV0 E30
    • Oct 2004
    • 8893
    http://www.realoem.com
    Just print out the stuff you need on realoem and you should be good.
    Are you taking out just the transmission to do it?
    I'd suggest taking out the engine at the same time. In fact that's the only way I'll do it. Makes putting in the hardline from the clutch master cylinder easier as well.
    I'd replace every seal possible on the tranny, and put in new fluid since you're going to be in there.
    Really the hardest part is just tightening the hard to get to nuts for the pedals.
