I have a '91 318is with an open diff - the diff has recently begun to whine, not to mention leak. I purchased a 'medium' LSD from a 325is off of craigslist. Now : I'd like to rebuild this diff, with new bearings and seals, etc. I have extensive mechanical experience, but I've never rebuilt a diff before. Things like "gear lash" have no meaning to me. Could someone direct me to some kind of guide, or perhaps steer me away entirely from attempting this?
Differential Rebuild Help
Tags: None
Rebuilding a BMW diff is not really a DIY kind of thing .
Without the proper tools the torque required to put pinion nut back on will cruch the bearings .
About the only thing you can do is swap the output seals and the cover gasket .
But with that being said the BMW diffs are pretty robust and should last quite some time before really needing a rebuild . -
my idea of a diff rebuild... new seals, cover gasket, and paint it bling bling black!Claus Luthe is my hero.
it's not hard to pull a BMW diff apart. I've got one pulled apart at the moment and I have the gear off of the limited slip unit. But I would not suggest someone pull it apart if they don't have diagrams/torque ratings/experience rebuilding one.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
IMHO, not worth it. Unless you are running a racecar or some specific event. For just average normal use and the occasional track day, it makes more sense to just get a used one, and if you happen to burn it up, just get another used one. Rebuilding will cost you 3x plus what a used one will run.sigpicComment
I think for a fully rebuilt one from Diffsonline.com is like 1500 for just the base. Then it starts to add up when they polish the gears, add clutches, etc etc. I think for everything to be done with a variable ramp and like 40% lockup is somewhere in the 2200 area.My 2.9L Build!
How'd you make out? Did you do the seals and gasket yet?
I was debating on doing the same thing.
Does anyone have any experience with a solid rear end? I'm not trying to sound like an idiot, I'm just curious if it's been done. I previously owned 4x4 jeeps before and used to weld spider gears together or have a selectable locker in the diff, LSDs, ect ect. Just wondering if anyone has had a fully locked rear end BMW and how does it drive on the street?Comment
Okay, I am an idiot. I should have searched before posting a stupid comment.
please ignore previous post.Comment
