So I'm having a bit of trouble with my 325i, and hoping to get some help from you all. Here are my symptoms:
It recently became very difficult to get my car into gear, particularly 1st, 2nd, and reverse. This happened over the course of perhaps a week before I got in one night and it just became too difficult with the car running to get it in gear. I turned the car off, put it in gear and turned the car on, when I took my foot off the brake (with clutch still in) the car started to roll slightly. So apparently my clutch is not fully disengaging.
I had not noticed any fluid leaking under the car, but I can't say for sure that there hasn't been any leakage. Since then I've tried flushing the hydraulic fluid, and I thought it was bled fully (no air coming out) but now the clutch takeup is even worse - that is, there is more play before I feel resistance. Also if I start the car in gear it wants to move, so the clutch still is not fully disengaging. I plan to bleed it again with my pressure bleeder, but am concerned that this will not fully solve my problem.
When I bought the car a little under a year ago the clutch was significantly stiffer than any I had ever driven before, but figured somewhere along the line someone replaced with a performance clutch that was much stiffer. The pedal feel has since stayed very stiff, with the clutch grab point always being very close to the floor and very short travel between fully disengaged and fully engaged.
Now after reading a bunch of threads I'm starting to think it is my pressure plate. I really don't want it to be my pressure plate, because I don't have the time/experience/desire to replace it myself (judging by reading posts of other people on here replacing their own clutches), and obviously it's fairly expensive to have a shop replace the clutch. Unfortunately I am starting to doubt it is a fluid problem, but I am welcome to encouragement that this is the problem.
Sorry for the long post, but in short, do you agree with me that it is a pressure plate failure? Or do you think that it could still be a hydraulic problem? And if so, why?
