Do all stock ETAs suck as much as mine?
  • TopOfTheLine89
    • Jun 2007
    • 919
    i just went out to do a 0-60 run(which i knew would be disappointing) and to see how far each gear went, 1st:15MPH 2nd:35MPH 3rd:55mph 4th:65 maybe? would swapping in a different differential help me out any? cause the results i found were ridiculous. when i did the 0-60 i just counted myself which im sure is very inacurate but i cam up with about 13 seconds.?
    anyone?
    97 tacoma 5 spd 4 cylinder
    2001 330ci 5 speed
    83 733i 5 speed, (FS)
  • backtrail69
    • Jul 2005
    • 4471
    Um... WTF.. My car goes like 30 in 1st, 55-60 in 2nd and 85ish in 3rd... your car has the incorrect rear end in it...
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • JasonC
      Site Manager
      • 14451
      I have two eta's and they do put you to sleep. My 85 has a 3.73lsd under it and has a long tube header with free flowing exhaust. It's not too bad i guess??? But when i got another on i took it for a drive and i was like WOW "this is slow".... It's stock with a 2.93lsd in it. And both are 5speeds.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
      • TopOfTheLine89
        • Jun 2007
        • 919
        I think your right cause i just plugged in the stock ratio's on a calculater and a stock eta should go 30 or 31 in first. Can anyone else back up that their eta does 30 in first?
        2001 330ci 5 speed
        • JasonC
          Site Manager
          • 14451
          I seen your WTB ad and didn't want to clutter it up. What gearing is in the car now?
          1992 BMW 325iC
          • TopOfTheLine89
            • Jun 2007
            • 919
            4.10 i think
            2001 330ci 5 speed
            • JasonC
              Site Manager
              • 14451
              4.10's I thought i was crazy when i put the 3.73lsd in my eta :crazy:
              1992 BMW 325iC
              • TopOfTheLine89
                • Jun 2007
                • 919
                Yeah, im glad i finaly realized cause i was thinkin, damn, i cant reach 60mph in 3rd gear?wtf?
                2001 330ci 5 speed
                • SpecM
                  • Oct 2005
                  • 4531
                  -I had a 4.10 in a '88 s-eta (5300 stock redline). It topped out at 110 before I did the whole 2.7i thing.
                  -I wrecked it tho. Too bad. :( A gutted (2500lbs) 2.7i with a 4.10lsd is pretty quick.
                  1989 cirrisblau-metallic 325i
                  • TopOfTheLine89
                    • Jun 2007
                    • 919
                    If im gonna do the 2.7i stuff should i just keep the 4.10? will putting the 2.93 mess up my speedometer.
                    2001 330ci 5 speed
                    • SpecM
                      • Oct 2005
                      • 4531
                      -You need an '88 engine to do the "2.7i stuff".
                      -And No, cuz the speedo is run from the diff itself.
                      • 86espowa
                        • Jun 2007
                        • 296
                        My eta had a 4.10s in it that i never knew of.
                        would pull off the line with a vengeance.
                        • Sean
                          • 5793
                          That's crazy! My supereta topped out at 110 with a 3.73! WEEIRD
                          - Sean Hayes
                          • TopOfTheLine89
                            • Jun 2007
                            • 919
                            Yeah, i wasn't gonna put on an i head, just the "i" cam and valvesprings.
                            Tonight i just found another surprise with my car, i recently swapped in a 7K tack and tonight was the first time i had done any rain sliding since, well i the tires started spinning and i reved to 6000+ rpm, shouldn't there be rev limiter?why is it gone? Im starting to wonder about the previous owners? is that easy to remove the rev limiter? could someone accidently do it? could i have a i or is ECU?
                            2001 330ci 5 speed
                            • AndrewBird
                              The Mad Scientist
                              • 11892
                              If all you did is put in the 7K tach without swapping out the coding plug, then the tach is reading inaccurately, hence your problem.
                              If you did swap the coding plug and it IS reading accurately, a performance chip would raise the rev limiter. But it sounds like you didn't swap in the coding plug given the fact you can only do 15mph at an indicated redline.
