my drain plug on my tranny is on the verge of being stripped. its a 17mm hex nut and whoever had it before me obviously stripped it. im trying to replace my tranny fluid and this #%@$ plug wont come out without wanting to strip! what should i dooo?!?!
stripped drain plug
stripped drain plug
8heat up my drain plug with a torch, try to take it off25.00%2take next size up hex wrench, file it down so it fits what i have0.00%0other: (list your idea in your post)12.50%1cry62.50%5e30s r koolTags: None -
they're sockets, with sharp flutes. When turned with a wrench or breaker bar, they bite into the nut and it moves.
see http://www.sears.com/shc/s/p_10153_1...yword=bolt+outComment
ok that looks like what i need if i had a regular drain plug (ie oil drain plug) the tranny drain plug on my car has a threaded outside..and the wrench goes on the inside of pluge30s r koolComment
Sorry, you're right, probably wouldn't work for you. Can you hammer in the next size up torx or hex bit in?
I know that the female allen bolts on the axles are a pain in the ass until you clean all the dirt out of the hole. They're deeper than they appear, and once you clean the hole out entirely, the allen socket will sit better. For those my best luck has been with a half inch drive allen socket and a 3 foot breaker bar. I'll often hammer the bit in to get it deep in the hole.Comment
this drain plug isnt deep at all...its like 1/4 inch deep and yea stripped to shit...and probably hasnt moved in like ten years...
dont they have a bolt out with the sharp threads on the outside?
blahhhe30s r koolComment
hmm cooper that sounds like it may work...im gonna have to play around with that idea...i just dont want to me stuck with a plug that wont come oute30s r koolComment
#%@#%@ ok sooooooooooooo #@@#
the drain plug is 17mm , my hex 17mm will strip it if i use it...
so i bought a 19mm, the next size up, and have been filing it down to get it to fit my plug...but it takes blippin forever ive been filing for the last hour blahhh
then i tried channel locks, to grip the threads on the outside and twist it off....after a few muscling tries...i gave up on that one
i dont give a shit what happens to this plug...because ill get a new one to replace it with...unless bmw wants to charge me 50 bucks for one.
i looked on bavauto but they didnt have one listed for my car...anyone know where i can get another one from somewhere else?
so i have 3 options,
take it to someone and pay 20 bucks for them to take it out..
keep blipping filing the 19 till it will fit
drill it out like cooper said, which is something im still skeptical about because what if it still doesnt come out after i drill it??
blah i need advicee30s r koolComment
How about a chisel and a hammer? Chisel around the outside of the plug and hopefully it will move. Drain plug I think is part number 23117527440 and retail is $5.08 I found it on this page. number 2 http://www.realoem.com/bmw/showparts...10&hg=23&fg=15
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
take it to a mom pop muffler shop have them weld a hex head bolt of 17mm dia into the allen hole on the tranny drain bolt... then put a socket and pull the sucker out... ask me how I know this works
dont wast your time with Midas and those other places. They wont touch a job like this for fear of liability. I found a biker own shop and the guy did it for $15 and only took about 10minutes. they even cleaned the threads afterwards.
I have them do the same on a junkyard exhaust that had a tore up o2 sensor in it. The nut on the sensor was strip so I had them weld a 1/2 dia hex head bolt to the remains of the o2 sensor and was able to take out the nut that waysigpic
- 0.05s and 0.1s FTW!!!Comment
