getrag 260 from e to i compatability
  • chrisesteschiro
    • 361
    Hello I was searching and read on e30 tech
    "You have to run a different T/O bearing since the actual eta bell housing is alittle differently shaped. I beleive it is from the 533, but definately check that one out. James Criv on R3v knows the part number for sure."
    When using an e 260 in an i, Please tell me its not true!!!! Thanks
  • DarkWing6
    • Apr 2004
    • 7144
    if you are using a 260 that came from an e in an i you need a e28 (i think) to bearing. if you want to order one call patrick at BMA and just tell him you need the to bearing that james crivellone used with his tranny.
    • chrisesteschiro
      • 361
      NOOOOOOOO, I just put the engine and tranny back in the car then I read this!!!!!!!!!!!!!!!!!!!
        • 37833
        It's true. When I did my i swap with e tranny I used a regular i t/o bearing. It started making noise within 2 weeks.
        Grover Beach, California
        BimmerHeads.com
        • PУCCKAЯ_e30ka
          • Jan 2006
          • 1226
          kinda off topic... but anyways, gtrg 260 from 525 work in my '91 325?
