Center Support Bearing problems
  • TerribleONE
    • Jul 2006
    • 501
    so i finally got around to replacing my horrible center support bearing, and i put in the new one, put everything back together and there is still a similiar vibration and obvious movement in the drive line. some one help.. :roll:
    1991 318iS swapped w/ euro S50B32
    -Michael
  • TerribleONE
    • Jul 2006
    • 501
    also i have a stock driveshaft from my 89' 325i, and i was wondering if the 325i driveshaft would fit in the 91' 318iS?
    -thanks
    -Michael
    • DaN
      • 1265
      Check the centering bushing at the tip of the driveshaft at the guibo, and the flex disc for cracks.
      Are the white dots on the d/s sections lined up?
      how are trans mounts?
        • 37834
        -thanks
        No, it will not.
        Grover Beach, California
        BimmerHeads.com
          When a center bearing fails the cause is almost always binding drive shaft u-joints. A new bearing may work for a while but the bad drive shaft will cause early failure of the center bearing. The only fix is a new or rebuilt drive shaft.
          • TerribleONE
            • Jul 2006
            • 501
            i figured out that the problem is the worn to shit guibo, but thanks guys!
            -Michael
