LSD Swap
  • E30nate
    • Oct 2007
    • 1050
    LSD Swap
    when i put in my LSD, what kind of additive should i put in it for the clutches? also would redline 75-90 be a good oil to run?
  • whiltebeitel
    • Apr 2007
    • 2098
    You shouldn't need an additive, and that would be a good oil to run.
    '89 325i track sloot
    '01 530i daily
    -Enginerd
    • E30nate
      • Oct 2007
      • 1050
      ok. the clutches wont burn up without an additive. i was told that on this style of lsd, you should run some sort of friction modifyer additive.
        Regular Redline 75w90 has friction modifiers in it. Redline 75w90NS doesn't.
        • E30nate
          • Oct 2007
          • 1050
          ok. so dont get the 75w90s. thanks for the help.
            • 37834
            I used a tube of limited slip additive I found at Auto Zone in my 4.10 LSD.
            Grover Beach, California
            BimmerHeads.com
