alright well i just intalled a new master cylinder and i went and bled the system as i have in the past
-started off with a vacuum bleeder mainly just to draw fluid down through the system (with vacuum bleeding its hard not to get air bubbles)
-took the slave loose from the tranny with bleeder at highest point i openned it and pressed in the plunger and i got a nice solid column of clear blue comin out, i did this about three times each time not a single bubble comes out
i get some pressure on the clutch pedal but not enough to actuate the clutch, and not enough to push it back up.
fairly new slave
new master
fairly new soft line
original hard line
fairly new slave
new master
original hard line
