Lucky punk.
6spd e30
My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
Originally posted by rkettner View Posti need a resource that would list factory driveshaft lengths for e30, e36, z3, z4 etc.
i'd like to see if there is an oem shaft that would connect my guibo to centre bearing without custom shortening.
if not i'll have to send it to a custom shop.
We've said from the beginning that a custom lenght shaft is a must .
Just suck it up .
Just go a head and contact The Driveshaft Shop and shell out for a custom one piece driveshaft. It'll run you 900 bucks, but you won't be breaking it anytime soon.My 2.9L Build!
update.
every single tranny bolt hole lines up and it doesn't appear to be tiled 10 degrees.(unless its hard to tell by eye)
input shafts are different between the two trannies. the 260 having far fewer notches on the shaft then the z4.
shift linkage doesn't look like it is going to be very friendly to swap. both of the linkages appear to be too long.
rear guibo is much larger on the 6 speed. are all e36's much bigger?
shift knob and redline oil have been ordered!
What about driveshaft?
Also, are you using this on an M20?My 2.9L Build!
What did you have done to the DS?My 2.9L Build!
