Alright, as some of you may already know, Yoshi and I did a 5spd swap in Donna. Well at the same time, I also installed a new clutch, throw out bearing, pilot bearing, and pressure plate.
Right now I am in the process of 'breaking in the clutch'. Well my 1st question is ... the clutch seems to catch very high, and the system is a hydraulic system, so how would you go about adjusting the clutch catching point? I think I am going to try to bleed the clutch line again and see what happens.
The 2nd question is... when starting out, I noticed that the vehicle feels like it's binding up. Like something is pushing against it when I go forward or in reverse?
I haven't had time to take a look at it, just trying to see if anybody has an idea.
Thanks for reading!
-Viet.
Thanks for reading!
-Viet.
