about my trans fluid
  • lovemy318
    • Sep 2026
    Whats a good generic brand of trans fluid that i can afford and use on my 85' 5 speed? how much should i get to fill her up?
  • Keith M
    • 2338
    Redline MTL is $ 9.00 a quart. Buy 2. While you are at the auto parts store, buy pump. $ 4.00.
    Keith
    • euroshark
      • Apr 2006
      • 3491
      Definitely go with Redline. For the few bucks you save by going with something else, it's just not worth missing out on the feel and protection Redline provides.
      • lovemy318
        i cant find redline at any of my auto parts stores. and why do i need a pump?
        • Keith M
          • 2338
          Srsly??
          To transfer said fluid from the container it came in to your transmission.
          You also need a hex socket. (14mm I think)
          Why?
          To remove the drain and fill plugs.
          Drain pan
          Why?
          So you don't dump it all over the floor.
          :D
          Loosen the fill plug first then the drain plug.
          Check with import auto parts stores (VW or the like) or order it online.
          Keith
          • lovemy318
            thanks keith
            • ecorrea21
              • Sep 2006
              • 18
              Four year's & 43K mile's ago I used Valvoine Race 20W-50 in my 85 318i's gear box and still running strong!!!!
                • 37833
                Just drain the tranny and refill with tap water, you'll be fine.
                Grover Beach, California
                BimmerHeads.com
                • Baxter
                  • Apr 2007
                  • 40
                  17mm ;)
