Hey guys when I let my clutch in I hear a bit of a thunk. This usually happens at low speeds when I can hear all the sounds the car is making. Also I don't know if it's related but when I'm at around 80mph the car kind of vibrates hard. Maybe a toasted guibo or something else?? What do you guys think?
Tranny Noise
Most vibrations at higher speeds will be caused by a problem with the wheels or tires and that's where you should look first for the 80mph problem.
A clunk when releasing the clutch could be a problem with the drive shaft, but it could just as easily be from bad motor/trans/diff mounts or worn rear suspension bushings. A through inspection by experienced BMW tech should reveal probable causes.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
i have a vibration from 40 to 75ish, and from what i found was that my control arm bushings need replacement.Captain, we need more power!!!!
Hmm, well a thorough inspection would make me wanna kill myself cause I know he/she would keep going, "And that, and that, and fix that..." Dammit. Hmm, so any bored bmw tech's wanna diagnose my car? :DOriginally posted by csermonet47Vlad, you are handling this quite unprofessionally.
Also, you are a cock with tacky taste.
That is all.Comment
Sure, bring it to Huntsville and I'll go through it. But be warned that it probably will be a "you need to replace this, and that, and...". You have an 18 year old car and unless it has been religiously maintained there's probably a good bit of maintenance/repairs needed. The good news is that these cars are very easy to work on and parts are readily available. While the laundry list from a through inspection might be initially depressing, not everything will require immediate action and you'll know what needs attention and can plan out a schedule of repairs. A good tech will tell you what needs immediate attention and what can be deferred for a while.Hmm, well a thorough inspection would make me wanna kill myself cause I know he/she would keep going, "And that, and that, and fix that..." Dammit. Hmm, so any bored bmw tech's wanna diagnose my car?The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
