Anyone has some of the shims used to set the side play? I have a 1.84 and a 1.36 and they are too thick; the diff won't turn when everything is tightened down...any suggestions would be helpful.
Need some shims for the OBX limited slip diff install...
BMW still has them, I think. Not specific to the OBX.
http://www.realoem.com/bmw/showparts...16&hg=33&fg=10 -
skim some off your existing ones then perhaps?Just a little project im working on
- http://www.lse30.com -Comment
OK it looks like the OBX unit is NOT going to fit. Even with the shim pack the shop can't get the pinion/gear set up properly. Seems the carrier isn't the correct thickness to allow the gear contact patch to be within specs.
It figures, this is the last thing to do to get the car on the road...any suggestions from those who have installed this unit?Comment
