1st and 2nd gear wont go in, my other gears are fine just the first two. I have a video what it does when im tryin to put it in the gear. Just stops half way.............
ok before this happended i'll tell you what i did.....I put it in 1st gear and i started goin and it was kinda wet outside and i was turning right so i kinda hit it and when it hit the rev limiter i switched to 2nd but couldnt it started grinding so i put it back to netural and since then 1st and 2nd dont work....
synchros??
Thanx
Thanx
