ujoints
  • Burning2nd
    • 98
    ujoints
    are the u joints on the drive shafts replaceable?
    when i drop the exshaust and heat shield for the drive shaft center bearing replacement,
    i would like to replace the ujoints
    are they all the same... will my local NAPA carry them?
    04 e83 X3
    01 e39 540M
    97 e36 328is
    Specializing In BMW, Audi, Mercedes Benz, Porsche ,Volkswagen
    The u-joints on a BMW drive shaft are not field replaceable. They'll be welded or staked in and will require machining as a part of the replacement.
    • homegrone30
      • Jun 2007
      • 1449
      has anyone here with the know how performed this procedure before. Cause im wondering about this too. I dont think that i could afford a driveshaft and this would be at least worth trying.
      • IveGotIssues666
        • Oct 2006
        • 517
        They're only held in with tack welds about 6-8 welds on each cap. You should be able to just cut the welds and pop the caps out and then replace the u-joints and then make some tack welds on the caps. Only issue I would say ould possibly be re-balancing the driveshaft but I even doubt that for when I replace U-jointson driveshafts at work none ever need re-balancing.
        So it is DIY just not as simple as removing a S-clip and removing the caps etc..
        Jared
        • Sean
          • 5793
          I bought mine from Mesa Performance in California. Replacement driveshaft, with u-joints that DONT require greasing - for like $350 after core return. Not bad, I don't think!
          - Sean Hayes
            • 37832
            We use a company that rebuilds driveshafts. Costs $300-$350.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • homegrone30
              • Jun 2007
              • 1449
              ok but has anyone actually tried to do this i might try but i dont even know where to begin with figuring out the size of the u-joints
              • Sean
                • 5793
                I wouldn't reccommend it. BMW has these made to where they are not serviceable. I'd just get a rebuilt one from Mesa or Driveline Service of Portland.
                - Sean Hayes
                • IveGotIssues666
                  • Oct 2006
                  • 517
                  Last time I remember I thought I saw www.autohausaz.com carried them for $20 each
                  If you can tack weld you can tackle this.
                  Jared
