93~96 M3 3-DS 5sp Trans in an E-30 M42?
  • DCColegrove
    • 2748
    93~96 M3 3-DS ZF Trans in an E-30 M42? Has anyone done it here?
    If so what was the physical and psychological damage incurred?
    It would be nice to know before I buy 2 cores and make the measurements my self.
  • FredK
    • 14763
    Hmm, that's an interesting swap! I am fairly certain the G240 and the ZF have the same bell housing pattern, because the 240 bolts right up to an M5x-family engine. My guess is that the transmission will sit fairly forward, so you might have to get creative with the driveshaft solution.
    I do have a 240 in the garage, would it help to get a height measurement or something?
    • DCColegrove
      • 2748
      It's a long story... I can tell you that a 240mm clutch and billet 16lb flywheel will fit in a little Getrag (started the job on Thursday morning... Done late Friday afternoon...whatamotherfuckandbloodshed).
      I know that the little 240 will blow soon so I need to line up a new option...and if the ZF isn't too much of a hassle I think it's the best bet...Only problem I don't seem to have one around... will it even fit in the tunnel??? Dunno?.
      • FredK
        • 14763
        Yeah, it should fit fine. The ZF310 or 320 isn't that big. It fits fine mated to an M50 engine.
