how do you guys take the shifter selector rod seal out?
  • scobaru
    • Nov 2007
    • 396
    this was taken from the http://www.pelicanparts.com/BMW/tech...t_Bushings.htm
    DIY
    the trans is in the car still, I dropped it a little bit from the rear bolts and can't get that seal out I have really tiny pick tools and they can't seem to get it out... I have some decent amount of space under the car but any advice?
  • 330SMG
    • Feb 2007
    • 172
    DIY
    You gotta get a little rough, I actually used a little flathead screw driver with the head cocked 90 degrees.. You catch from under the rubber and just pull, you und up bencing the race around the rubber and then it should just pop out. Usually the spring comes out first . Hope this helps.
    1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
    • scobaru
      • Nov 2007
      • 396
      sweet thanks... looks like I'll have to bend a screw driver
      • mops
        • Jan 2006
        • 138
        yeah, basically you need to use seal remover/puuler tool, which is basically a small, sharp, thin bent hook that you basically stick through the rubber (wrecking the seal) and oulling that metal ring out.
        • bala_eos
          • Sep 2004
          • 58
          That seal is rubber on metal. The usual seal picks didn't work for me. A small flat blade screwdriver (from an electrical tool kit) did the trick.
