Hi, me and a friend have been trying to remove the transmission from his 87' 325is... Does anyone have a pic of the Transmission and a pic of the bellhousing? We got everything off and ALL we have to do now and get the top bolts... and they are next to impossible to remove... How do u get the engine and transmission to tilt back MORE for more room to see and reach the top bolts on the transmission? Thank You!
Pic of 325is 5spd bellhousing and Removal Help!
Ok - here's what you gotta do.
First - go to realoem.com and take a look at the correct pictures. Will help you visualize where the bolts are you want to get to.
I take it you have already removed the tranny mounts? If you haven't - do so. Then get a jack on the front of the oil pan, and push up on the front of the motor - with rubber mounts I've tilted the motor back to the point where the valve cover sits on the firewall - it won't hurt them too bad. This gives you enough room to get a nice long extension up there.
You'll need multiple extenders and at least one universal joint. To reach those top ones, I think I needed like almost 2 feet of extensions total - it's tricky, but can be done!
Don't forget to get the starter bolts too. Those are a real bitch because you have to losen one side and hold the other, but it's doable.
Let me know how it goes.- Sean Hayes -
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
