in my car now is a open 4.10 and i wanted lsd and a little better on the highway. so i found a local 1985 323i parts car i was just wondering whats in it for a rear end? and will it fit my 1991 318is?
what rear end is in 1985 323i will it fit my 318is?
91 e30 318is M50 SOLD
http://www.r3vlimited.com/board/showthread.php?t=149570
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Tags: None -
someone in here will be able to tell you for sure, but i think the iS was one of the models that used the medium case, 188mm diff like the 6 cylinder range.
So yeah, if the iS used the larger diff compared to the other 4 cylinders, it should fit. However, the 323i usually came with a 3.64 rear, but it might not be an lsd anyway.Just a little project im working on
- http://www.lse30.com - -
its got a med case 3.23 or 3.91 (some sport models), LSD if its sport.Comment
