Well I was driving home from work the other day and shifted from 2nd to 3rd, clutch felt normal, but when I shifted to 4th the clutch felt noticably heavier. Didn't hear any abnormal noise until I got almost home, had radio turned up for driving up the highway. The sound is definately a metal on metal grind, it is sligthly audible with clutch engaged and is screeching with the clutch disengaged (pedal depressed). I'm thinking it's the throwout bearing. I did notice a few months ago a slight noise if I was stationary with the clutch engaged. I have a new clutch set ready to go in, cause I'm not sure of the mileage on the current one. I also have fresh seals to go in while I have the tranny out.
A Friendly Metal on Metal Screech!!
Sounds like TO bearing, that's for sure. If you feel like it you can do the input/output and shifter seals and do a quick fluid change, just to be thorough and not have a reason to drop it again.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
