Flywheel question...
  • TDE30
    • 7042
    325i flywheel and 325e flywheel, are they the same?
    Help is appreciated.
    - Trey
    E90 325i/6 (ZSP, ZPP, ZCW)
    E36 325i sedan
    E30 325i sedan
    Volvo 945T
  • justin_l_
    • Jun 2007
    • 1079
    Depends. Some were dual mass and some were singal mass.
    • Aptyp
      • 6584
      Simple answer. No.
      • rThor432
        • Feb 2007
        • 3907
        Semi in-depth answer--
        Early eta's had a heavy single mass flywheel that was essentially the same as the later B25 flywheel, although it weighed about 4-5 lbs. more. The early eta flywheel is 23 lbs iirc. The B25 flywheel weighs about 19 lbs.
        The late eta had a dual mass flywheel, that weighs a ton and just sucks. It weighs around 27 lbs.
        • TDE30
          • 7042
          Ah, okay. Thanks for the information.
          - Trey
          E36 325i sedan
          E30 325i sedan
          Volvo 945T
          • Rob
            • 8166
            Ryan, so a supereta would have the heavy dual mass? Meaning even a stock 'i' fly would be an upgrade...
            good info!
            BEERTECH
            • DCColegrove
              • 2748
              The I flywheel wont have a TDC ref mark for the old 25 pin DME sensor.
              • Flash
                • 691
                The early 528e flywheels were 13 pounds AND had a TDC pin!
                You can duplicate that by shaving the engine side of the flywheel down to the level of the ring gear but then leave about .010 of a lip, no TDC pin however unless you put one on.
                • rThor432
                  • Feb 2007
                  • 3907
                  I've got one of these in the command center.
                  Yeah Rob, all 9/85 and later etas have the giant flywheel. Even the earlier eta single mass flywheel is an upgrade (that's what I had in my eS). Mine was used with a B25i clutch and pressure plate. Worked good.
                  I weighed all of the flywheels one night at Mitch M's shop on a postal scale. The early 528e/320i/323i flywheel weighs 13lbs., the early eta flywheel weighs 23lbs., the late eta weighs 27lbs., and the B25i flywheel weighs 17 or 19lbs (pretty sure it was 19lbs).
                  • E30SPDFRK
                    • 5716
                    Will a late eta clutch bolt up to a early 528e flywheel?
                    Byron
                    Leichtbau
                    • Flash
                      • 691
                      All the bolt patterns are the same for the m20 flywheels, the question is will the stack height be the same.
                      The pressure plate is a lot thicker for the 325i to make up for the shorter flywheel, realoem would tell you if the part numbers are the same anyhow. Dual mass does not use a sprung hub since the flywheel is spring, and single mass....vice versa.
                      • Mike
                        • 932
                        interesting, how about those 323 ones?
                        Supatek -noun - your basic know it all
                        • cobraken
                          • Oct 2004
                          • 674
                          Uh, can someone help me out on this? I am getting ready to install a 325i engine in my 86 325e and dont fully understand the flywheel issue.
                          Assistance is needed.
                          Randall Racing and Engineering
                          Acworth, Georgia, 30101
                          http://www.facebook.com/RandallRacingandEngineering
                          • cobraken
                            • Oct 2004
                            • 674
                            Here is my VIN if this helps WBAAB5407G9634771.
                              You need a single mass flywheel from a 325i/is, matching clutch, pilot bearing and throw out bearing.
