tranny output flange
  • TS87325IS
    • Sep 2006
    • 821
    is there a difference between output flanges of the early style and later style getrag 260 ? I have an 87 325 is with a stock tranny , I need to replace it due to no third gear , it has the bitch clip shifter style set up , I have another tranny that is the bolt in shifter style which must have came out of a 325e , the output flange has studs on it and my stock one did not , before I rip the tranny out and try to swap the flanges out , I want to know if it will work or if I need to get a different guibo and an eta driveshaft or can I simply swap the flanges. any help is appreciated , thanks.
    mods: just meat and potatoes under the hood and wheaties on fire out back ;)
    You can swap the flanges. Replace the output and shifter seals at the same time.
    • TS87325IS
      • Sep 2006
      • 821
      Thanks , I wasn't sure if the inner diameter of the flanges were the same.
