I've done some researching and can't find anything that seems to help with the issue I'm having. When I'm turning at relatively low speeds (when in reverse, first, second, and sometimes third) and when the transmission is engaged, I hear what appears to be a grinding noise coming from the rear of the car. It almost sounds like tires rubbing, but I've already checked that. It doesn't sound like pure metal-on-metal grinding/rubbing, but I can't for the life of me figure out where it's coming from. Any ideas or similar situations? Danke schoen in advance...
Rubbing/grinding noise...
My e30 thread...http://www.r3vlimited.com/board/showthread.php?t=120348Tags: None -
a limited slip diff will make funny noises at low speed turns.
Is the vehicle new to you? The PO could have installed one. You can tell by checking the metal tag on one of the diff cover bolts.
On the other hand, it could be dead output bearings in the differential. -
My LSD was a bit noisy until I put Redline into it; haven't heard a peep since...Originally posted by chileelkyamaze about the enthusiasm e30 generateComment
Was it noisy whether or not the clutch was engaged? The noise for me for goes away if I've got the clutch pedal pressed.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
My e30 thread...http://www.r3vlimited.com/board/showthread.php?t=120348Comment
when you depress the clutch, the lock in the diff opens up and thus no more differential clutch scrub noises. I've not heard of a LSD make a dramatic grinding noise, though mine was pretty bad at one point and has since gone away... maybe mine is toast.... hmm.
But the tag will have an S after the number. The gear ratio will be printed on it as well. It should be like 4.10 or 3.73, to name a couple possibilities.
If the diff were removed from the car, it could have an S painted on the top of the casing.
do some searching about the topic. there are ways to quiet the noise but otherwise, dont worry about it.Comment
do some searching about the topic. there are ways to quiet the noise but otherwise, dont worry about it.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Do Redline in the trans too. The getrag trannies used in these cars are notorious for input shaft bearing noise, which is present in neutral but goes away when you depress the clutch pedal. I am not even sure if this is what you mean, but it's a good idea nonetheless. Redline is good stuff and made both ends of my car nice and quiet.Originally posted by chileelkyamaze about the enthusiasm e30 generateComment
Do Redline in the trans too. The getrag trannies used in these cars are notorious for input shaft bearing noise, which is present in neutral but goes away when you depress the clutch pedal. I am not even sure if this is what you mean, but it's a good idea nonetheless. Redline is good stuff and made both ends of my car nice and quiet.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Limited slip 3.73 ratio. Best all around diff for an m20b25 IMOOriginally posted by chileelkyamaze about the enthusiasm e30 generateComment
I LOVE the Redline fluids. I have MT90 in the trans and my 4.10. Surprisingly, I don't have the Getrag rattle. I'm not sure if it is was just a well kept tranny, or if the Redline actually had something to do with it. I never got to hear if the tranny did rattle before I put the fluid in due to a blown motor that came with the car.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
I LOVE the Redline fluids. I have MT90 in the trans and my 4.10. Surprisingly, I don't have the Getrag rattle. I'm not sure if it is was just a well kept tranny, or if the Redline actually had something to do with it. I never got to hear if the tranny did rattle before I put the fluid in due to a blown motor that came with the car.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
FYI...that friction modifer worked. All noise is gone!Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
