Hey,
So today I tried replacing and bleeding the brake and clutch fluid for the first time. I think I did the brakes right, but I had some trouble with the clutch.
The fluid that initially came out of the slave cylinder bleeder valve looked like really dark rusty water. I was able to drain maybe a two foot tube's length of that fluid, but then nothings coming out when I pump the clutch pedal. My procedure is like for the brakes:
1) Bleeder valve closed, have someone pump clutch several times, hold it down
2) Open valve.. but nothing comes out
Shouldn't something be coming out like with the brakes? Could this be a clog from the really bad old fluid? I tried pumping with the valve open as well and got nothing
BTW: I can drive the car just fine. In fact, it feels just like it did before I let any of the fluid out. Also, I didn't even use a complete 32oz bottle of brake fluid for the brakes, does that sounds righT?
Thanks
Thanks
