Clutch/flywheel question
  • kendogg
    • Jul 2006
    • 348
    Just need confirmation that an M30 flywheel/clutch will infact work on an M20. Been told all I need is a matching starter. Is this correct? Also, should the pedal height be roughly the same as well?? Looking to go with a 22 lbs. stock 535i flywheel. Thanks.
