Bavauto CSB
  • brantleyr
    • Apr 2008
    • 375
    Bavauto CSB
    Anyone have any comments on the quality of the CSB's shipped by BavAuto. Want to make sure they are sending me quality parts before I re-replace my csb. I think my driveshaft may be going out. But id like to know if its their CSB that went out or my driveshaft, before I put another one of their CSB's on.
    A failure of the CSb is almost always caused by binding u-joints in the drive shaft. While one can replace the CSB and have short term relief, until the drive shaft is replaced no CSB will have appreciable life. Replace the CSB and drive shaft at the same time and you won't have to worry about either for another 100k or so.
    • brantleyr
      • Apr 2008
      • 375
      Brantleyr.
      I was simply wondering if anyone else on the forums had ordered CSB's from BavAuto and what their experience with using the product was. Thanks
      • peerless
        • 285
        All the CSB's are typically the same. They all typically use WorldPac parts system. You have Febi, Karlyn, and Lemforder.
        You drive shaft is shot. Its 20 yrs old and been through hell. The u-joints are bound up and I am sure your flex disk is already shot as well.
        The driveshaft 'floats' in the CSB. If the driveshaft is in good shape there is no stress on a CSB.
        • brantleyr
          • Apr 2008
          • 375
          Yea its not exactly "floating" anymore, it is flailing around in the csb frame. lol, I replaced the guibo and csb about a month ago. I will be installing a "new" used driveshaft in a couple of days along with new csb. Hope this one lasts a little longer.
          • mikegar
            • Aug 2005
            • 523
            yeah when you put the csb on make sure its on the right way. i put mine on backwards and it ended up going out shortly after.
            Originally posted by Ferdinand
            I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
            DIVING BOARD DIVISION DIVISION IDIOT
            • Adrian_Visser
              • Jun 2006
              • 2823
              it sucks that there's like four posts on here talking about this in the last week an i never read any of them before i went and replaced my guibo and csb last weekend... now i gotta do it all over again... with a new driveshaft
              '89 Alpine S52 with goodies
