While under the car last weekend, i tried to note exactly the parts that will require replacement in the near year.
I have been chasing down a gear lash problem that i believe is almost solely due to the tranny.
But i have noticed a small amount of combined movement between the wheel hub to the drive shaft. Halfshaft to hub is a small amount + diff. output to halfshaft is a small amount + diff. input to output is a small amount + driveshaft to input is a small amount = ending up with around 2-5 degrees of driveshaft rotation, when the wheels are on the ground.
My question is, how much motion is normal for a new car? I have around 200k on these driveline components and would like to refresh/solidify the components by removing the gear lash. Would this expensive parts replacement considerably reduce this motion? I'm guessing new componets would provide a completely solid setup... just looking for anyone's experience in this matter.
