so here is what happened: I went to jump a friends car and his battery is shot so we revved my engine at about 2500 rpms for a few minutes. when we finally got his car started mine wouldn't do anything but go in reverse. I assumed I destroyed my tranny somehow, but it will still pick up speed in drive. Just EXTREMELY slowly. is it possible that i just slipped gears and could fix it by realigning them or is my tranny shot? need mechanical advice.
transmission problem
Fuckin noobs...search!
Just kiddin jeff :)
I have heard rumors that BMW trannys get pissed when you r3v them in park/neutral.
You may have burnt it up....sounds like its time for 5-speed swap.
Andy-Andy
+1 for a tranny swap. sounds like to me that its burnt up.Comment
Reving a 4hp22 in nuetral (or park) is bad for themso here is what happened: I went to jump a friends car and his battery is shot so we revved my engine at about 2500 rpms for a few minutes. when we finally got his car started mine wouldn't do anything but go in reverse. I assumed I destroyed my tranny somehow, but it will still pick up speed in drive. Just EXTREMELY slowly. is it possible that i just slipped gears and could fix it by realigning them or is my tranny shot? need mechanical advice.
I have the same problem, and found a broken spring in my valve body.1989 cirrisblau-metallic 325iComment
