New dif going in (3.91 LSD), did I F myself...
  • Cha Ching
    • 1668
    Hi guys, I'm a newb to the E30 scene, my ride of choice being a '88 325i vert w/5spd & 200K on the clock (& the rest of the car, for that matter).
    Anyhow, I had a local BMW specialty shop (Accent BMW in Lawndale, CA) look the car over & they say that besides new wheel bearings, it sounds like the dif output needs to be addressed (the car makes a humming" noise under throttle & while driving which sounds like it's coming from the rear dif).
    I just picked up a 3.91 (or 3.93, gotta clean the tag) LSD dif to swap in, but I'm not sure if it will fit. Somewhere I read that this gear ratio is supposed to be for 4 cyls. only, can someone here confirm?
    Thanks for helping the new guy...
  • Van Westervelt
    • 9365
    What car did it come out of?
    • Cha Ching
      • 1668
      Not sure, the seller thought it came out of a '87 or '88 325.
      • Mossman
        • Apr 2006
        • 1961
        uh oh, probably a 2.93 which will be a dog, get that tag clean or count the input shaft spins to output shaft spin ratio before you take the trouble of swapping it in
        • Cha Ching
          • 1668
          The tag definitely says 3.91 (or .93, I have to go check).
          • SpecM
            • Oct 2005
            • 4531
            US market 325iX's came with a 3.91 LSD (different LSD unit than a 3.73/4.10, tho)
            or maybe it is a 2.93 out of a 86-88 325/e/es
            1989 cirrisblau-metallic 325i
            • Cha Ching
              • 1668
              SpecM is spot on...The tag says 3.91 which means it probably came out of a iX. Overall the condition is pretty darn good. Doesn't look like it's been taken apart or damaged in any way. The guy I bought it from left it dirty so I could see that it's not leaking, that the bearings aren't going bad, etc.
              I'll try to get pics up just for giggles...
              • kronus
                • Apr 2008
                • 13032
                list of diffs: (stolen from da 'tech)
                318i/is
                1984-1985 - 3.64 (84 open for Auto)
                1991 - 4.10 (Manual)
                318ic
                1991-1992 - 4.27 (Manual w/ LSD option)
                325
                1988 - 2.93
                325e/es
                1984 - 1985 - 2.79 w/ LSD option
                1986 - 1987 - 2.93 (es = LSD)
                325i/is/ic
                1987 - 1988 - 3.73 (is = LSD)
                1988 - 3.73 (Automatic; iS = LSD)
                1989 - 1993 - 3.73 (Manual; is = LSD)
                1989 - 1992 - 4.10 (Automatic; is = LSD)
                325iX
                1988 - 3.91
                1989 - 1991 - 3.91 (Manual)
                1989 - 1991 - 4.10 (Automatic)
                M3
                1988 - 1991 - 4.10
                1988 - 1991 - 4.45 (rare)
                325i Touring
                3.91 (LSD = option)
                cars beep boop
                • alpinweib30
                  • Nov 2008
                  • 135
                  dude if you are replacing the whole diff its easy.4hours of work. i just did it to my car twice in one week AND took apart the lsd for my first time. 2.93 open to 2.93 lsd. im a noob as well but these things are easy to work on
                  86 325e limo
                  build thread
                  http://r3vlimited.com/board/showthread.php?t=126204
                  • wagonizzle
                    • Sep 2006
                    • 443
                    I believe this diff is viscous instead of clutch packs, if you didn't already know.
                    Originally posted by chileelky
                    amaze about the enthusiasm e30 generate
                    • e30polak
                      • 6136
                      318i/is
                      That ratio with a 6 speed would be soooooooooooo much fun!
                      INSTAGRAM: @UNDR8D_EMPIRE
