I've wrapped up my 5 speed swap a couple months ago, and finally finished all electrical work and installed the battery. Now I am finding out that I still don't have reverse lights. I tried searching for the thread, but to no avail. I did fiddle around with the harness spliceage, under the shift boot area, and was pretty sure I got that right. I thought that those reverse switches on getrag 260's were bulletproof, maybe it is bad...
m20 5 speed conversion question
Originally posted by PУCCKAЯ_e30ka View Postgo to E30 tech, I think in their tranny section there is a write-up by "promotor", his wiring is what I used to get my car moving and rear lights working, but I'm gonna try and make the cruise control work.The car makes it possible, but the driver makes it happen.
Will it fit 86-325E-5sp into a 92-325IC auto
Hello All I would really appreciate your Help/Expertise Please.
Before I start something that has no ending. I have a 86 325E 5sp Donor car. I would like to convert my 92 Auto. Would the stuff form the 86 fit the 92 325IC? Fly Wheel / Bell / Trany / D-Shaft / Starter / Ecu / ????.
All Inputs Will Get 5 Stars
Thank You
dj
( Yes it will work = ***** Goes to Yoshi SW. Thank You. )Last edited by dj01540i6sp; 03-17-2009, 07:27 PM.
This is proToMor btw (Everyone thinks its promotor...) aka yoshi
The big diff is that early model and late models have different drive tunnels so you have to get the right CSB for your car. In DJ's case, he has to buy a late model CSB because his donor is early model.
I got banned from E30Tech so I moved all my stuff out of there. Heres the new link http://www.e30performance.info/viewtopic.php?f=22&t=231
